Heads for my 5.3 build?
Old 04-10-2009, 11:54 PM
Epro's Avatar
Default Heads for my 5.3 build?
Motor has 137,500 miles on it
It's a 5.3 taken out of a GMC Sierra, building it for my 95 camaro. It's an iron block...
I was going to take the heads into a machine shop and get a valve job done, new valve seals, and have the heads plained. But I might get a slightly used set here! What exactly do the numbers describing the heads in the classifieds mean? Hard to explain... (317, 243)
If I get a stock LS6 cam, will I need LS6 valvesprings?
Old 04-11-2009, 03:40 PM
Epro's Avatar
anyone?
Old 04-11-2009, 04:01 PM
PREDATOR-Z's Avatar
those are casting numbers. You are going to build a 137K miles motor?
Take it from someone that did that many years back as a newb, DON'T.
You can rebuild the iron block and bore it to a 5.7L (346 ci), and as you said get a set of used heads in good condition. Either 5.3L or LS2/LS6 ported.
Old 04-12-2009, 12:27 AM
Epro's Avatar
By build do you mean rebuild? Or add performance parts like a bigger cam?
I figured I'd be safe with the stock cam out of an LS6?
Old 04-13-2009, 09:52 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
We offer cnc porting on the 5.3l heads for $650. We can build you a 2.00" 1.55" valve 5.3l head using stock GM valves to keep the pricing down
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
