Roller rocker question?
Ok I've found some 1.7 Harland Sharp rockers barely used for less than rebuilding my stock ones. What to do, I know I've seen one thread on here where the roller rocker failed, but they actually thought it was just a bolt.
LS1Tech Premium Sponsor
Selecting a rocker also depends a lot on your valve springs. You can easily cause valve train / valve spring problems when you swap to aftermarket rockers. We recently finished developing a all new valve spring that one of the main goals was to help cure some of these issues with installing aftermarket rockers. What springs are you running & whats your cam specs??
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
