Crank Differences
Crank Differences
Is there any differences between cranks in different year LS1's. I read they changed the main bearing tolerances in 2001. Did this change the crank? I've got a 99 that needs a crank and want to make sure any year will work.
i think the reluctor wheel was different for 97-98 cars than the 99 +. i noticed on the 2 98 cranks i have, the 2 wheels are pressed totally together, and the 99 crank i have is spaced about .0625 apart, and the 99 had more balance holes in it. not that the holes matter, but would i have to run a 99+ crank sensor with the 99 crank?
