What all needs to be changed when doin Heads?
Old 04-17-2009, 09:22 PM
corvet786c's Avatar
Default What all needs to be changed when doin Heads?
My car has about 90,000 miles on it and I wanna do AFR heads. Should I replace lifters, pushrods etc. What all should I look at Thanks?
Old 04-18-2009, 01:15 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Timing chain if you didn't replace it with the cam. Upgrade the lifters, new head gaskets, new head bolts
Old 04-18-2009, 04:13 AM
Michael02hawk's Avatar
1. Lifters & trays - most definetly.
2. New head gasket and bolts - of course.
3. Contact Tony at AFR! He'll set you up with the right heads, compression, porting if you want that extra umph, and anything else you'll need.
4. Proper sized pushrods - most likely.
Old 04-18-2009, 04:54 AM
98TA6.0's Avatar
90K? well if you dont plan on going back in for a while, i would suggest LS7 lifters, hardened pushrods, LS2 lifter trays, ARP bolts, new gaskets and seals, LS6 oil pump, LS2 timing set, and plugs.
Old 04-18-2009, 11:07 AM
Magic Man's Avatar
Check the cam and crank gears for wear as they can allow slop in chain.And replace the intake gaskets if not done before.
Old 04-18-2009, 01:51 PM
corvet786c's Avatar
Thanks guys, The cam is new, I have a new LS2 chain, I just have to do lifters and trays.
