heads/cam/springs/etc question
Old 04-19-2009, 03:11 PM
2001ws6-500hp's Avatar
Default heads/cam/springs/etc question
i know texas speed has a pretty nice deal on their cams, but i was wondering if anyone could suggest what the best way to go is, what i wanna do is buy a kit that has cam,pushrods,oil pump, springs(if needed) retainers, locks. im looking to get a 23x/24x and right around 600 lift. im trying to basically geteverything i need. or if some one is willing to sell their setup i would be interested as well.
thanks in advance.
Old 04-19-2009, 03:17 PM
bye the way, im a4, daily driven, weekend warrior, i plan on gettin a 3200 or 3600 stall. thanks.
Old 04-19-2009, 04:43 PM
anyone?
Old 04-19-2009, 06:20 PM
LS1-NAVY's Avatar
well if u r going to be in the 24x area i would say at least 3600 stall but i say get their ms4 cam kit with the prc 215 heads. search some m6 cars are very close to 500rwhp with that. also get a t-chain, and oil pump
Old 04-19-2009, 07:00 PM
i was wanting to do a cam only setup. maybe run thinner gaskets to add some compression, buy i do plan on buying chain, and pump. i looked at taxases cam packages and the niggest they have is a ms3. anyone selling a setup with an ms4?
Old 04-19-2009, 09:31 PM
LS1-NAVY's Avatar
tsp has the ms4 cam kit call them i, not sure u could run a thinner gasket with the ms3 or 4 to bump the compression up or i think u would have to fly cut
Old 04-19-2009, 09:35 PM
SOMbitch's Avatar
I would run a 4000 stall with MS3/4 and you have to run a stock thickness gasket without flycutting. They are close PTV clearance...
