Head Milling Question...
Old 04-27-2009, 08:10 PM
S10xGN's Avatar
Default Head Milling Question...
Hi All,
When you mill an LS* head, is there a point where the intake surfaces or the bottom of the intake manifold need "adjustment"?
TIA!
Russ
Old 04-27-2009, 10:47 PM
ramdaspadhye's Avatar
I think about .040 is about all you can mill 317's without running into intake fitment issues. Someone correct me if I'm wrong, but I think that's about right. I think you'll run into PTV clearance problems before you get too far for the intake not to fit properly.
Old 04-28-2009, 10:08 AM
67rsss's Avatar
Any V engine head will eventually need to have the intake milled to fit. Not sure what you do with the composite intake though.
