How far can I Mill my 806 heads W/O probs
Old 04-29-2009, 09:40 PM
blackcamarob4c's Avatar
Default milling 806 heads
ok. can I go 35mm? and what decrease in combustion chamber area? And what about a compression change with a stock Ls1 block? And any fitment issues with 1 3/4 inch headers. Also what will there be as far as a temp change..and any issues there. thx for ANY input, Mike
Old 04-30-2009, 01:55 AM
OMGWTFBODY's Avatar
Looks like milling .035" inch will provide a 10.65:1 compression, with is to say, about 5cc smaller than stock on those heads. That nets slightly better than 243 castings, stock.
Depending on the cam/spring combo, all I would think to be worried about is piston/valve clearance issues.
It's not looking like a ridiculous deck. Should put the heads at ~64 cc chambers.
Interessant... Correct me if I'm wrong, here.
Old 04-30-2009, 02:02 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Milling right around .007 is equivalent to removing 1cc of material from the combustion chambers.
Old 04-30-2009, 07:08 PM
OMGWTFBODY's Avatar
I read .005 and .007... Which is right?
Old 04-30-2009, 07:17 PM
ramdaspadhye's Avatar
Old 05-01-2009, 02:44 PM
Jakson's Avatar
If you mill much more than .050", intake fitment starts to become an issue. I had mine milled around .045 I believe, it came out to 61 cc chambers and it is at 10.98:1 with 4 cc valve reliefs in the pistons.
Quick Reply: How far can I Mill my 806 heads W/O probs
