Anyone use tubing for a lifter tool?
hmmmmm...good question... I dont remember what the diameter was......
But this is what I did
Once the car was apart, I found a screw/bolt that was about 2 inches or so long that fit in the hole.
Then I took it with me to the store and found some tubing that was a hair smaller than the bolt in diameter.
Before I left for the store, I measured the length of the block and made sure to get a rod long enough.
I found a piece of metal tubing that was 5 feet long, cut it in half, bent the tips so there would be a handle and put them in there..WORKED LIKE A CHARM and saved me 90 bucks...Have used it on 3 cars already
I had ordered a JPR lifter tool unfortunately they were on backorder, I used 1/4" od aluminum tubing (Helps to work in the HVAC business), it's the same stuff used for a pilot line on the old furnaces I had like 4 feet cut it in two about 6 inches longer than the block inserted it and just bent the ends up, I tested it by inserting the pushrods back in nothing moved so I ended up saving about 85-90 bucks.
