Dragon Slayer Crank Timing Mark
Old 05-12-2009, 08:59 PM
laughatrice's Avatar
Default Dragon Slayer Crank Timing Mark
Anyone know what the timing mark on a dragonslayer crank gear looks like. I'm thinking it's a very tiny tick mark anyone can confirm this making sure I got it right.
Thanks
Old 05-13-2009, 02:51 PM
Ok let me see if anyone can help with this.
Since I am not 100% I am reading the correct crank gear timing mark as it is different than stock and I can't fully see the crank gear or where the dot would be on a stock crank gear. Is it correct that piston #1 and #6 would be at TDC when the crank gear dot is at 12 oclock and woud this also be correct with a 4" stroke. If so then I can just put my cam gear dot at 6oclock when #1 and #6 are TDC.
Thanks
