Thread sealer?
Old 05-13-2009, 09:23 PM
Boo"SS"t's Avatar
Default Thread sealer?
Just a quick question on LS1 block: I'm getting ready to put my cylinder heads on. So, do I need to apply any "thread sealer" at all on any of the head studs (obviously on the block side)...????
Old 05-13-2009, 09:52 PM
conan's Avatar
I used arp moly lube on my studs, some peple will use locktite when threading them into the block.
Old 05-13-2009, 11:38 PM
Boo"SS"t's Avatar
My main concern is if there are any threaded holes on the engine block that actually goes thru any water jackets that would require any thread sealer.
Old 05-14-2009, 06:56 AM
UNDER PRESSURE MOD
The Alchemist's Avatar
Thread sealer is not needed, just moly lube that arp supplies. Hand screw them into the block till they bottom out, which make take a little bit of effort depending on the condition of your block threads, but after bottoming out, back them out an eigth to quarter turn.
Old 05-14-2009, 08:28 AM
Boo"SS"t's Avatar
Thanks!
