Cam lope question.... reverse split!
Old 05-24-2009, 08:37 AM
LS1Tech Sponsor
Superman09's Avatar
Default Cam lope question.... reverse split!
Well after hearing many cammed cars and watching many videos I have a simple question. I saw a vid of an MTI cam, specs 230/227 .591/.571 112. Anyways, in this vid, the lope to the car seems dramatically more noticeable than I was expecting from a cam of that size. It also seems as if the chop is much quicker compared to a normal pattern cam..... is this quick chop from the reverse split or something else? Finally, is a reverse split cam a good solution for someone who wants a driveable cam, but also wants that noticeable lope that a big cam gives? I bet that MTI cam is very driveable for its size, but it sounds beefy as hell! Heres the vid. Let me know if I am on the right track here or completely off. Thanks!http://www.youtube.com/watch?v=0IRLVR9lMmA
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 05-24-2009, 09:24 AM
Hardtop's Avatar
The cam in the video is an R1. The reverse split is an X1.
Old 05-24-2009, 09:31 AM
PREDATOR-Z's Avatar
IIRC the R1 is not a reverse, the X1 is.
A reverse with the proper valve events will be easier to tune and although with a nice amount of overlap it will not have the symptoms of bigger traditional splits at idle. This has to do with reversion from exhaust gases.
If you are interested in a good performing split grind, PM me I can suggest some specs that will deliver great below curve trq and still carry that power nicely on top. All of this while remaining very DD friendly.
One thing though, do not choose a cam for the way it sounds, choose it for the way it performs.
Old 05-24-2009, 02:44 PM
TXZ28LS1's Avatar
i gained 70rwhp with the MTI X1 cam swap alone. it has a nice lope, but more importantly its very drivable.
Old 05-24-2009, 02:56 PM
rubenlee21's Avatar
i have a reverse split thunder racing 230/224 cam on a 111. it has a good lope to it. kinda like a skipping lope. its drives really good. i made 406 rwhp too with only slp lid,s3 tb,pacesetter lt ory, slp dual dual cb, and dynotuned with hp tuners in my 2002 ws6 m6. im still on the stock 10bolt with 3.42 gears
Old 05-24-2009, 09:45 PM
LS1Tech Sponsor
Superman09's Avatar
weird, the title says R1 but in the comments he states the specs as the X1 reverse split.
Is it the reverse split that gives it the quicker chop or something unrelated to being reverse split?
__________________
Old 05-25-2009, 12:14 AM
BlueGoat06's Avatar
Cam overlap would give you the lope.
Overlap=((Intake duration + Exhust Duration)-LSA)*2, you can make a smaller cam lope like a big one without having to affect your under the curve power and driveability. i have a single pattern cam from TSP (228/228 112lsa), that lopes really good, you wouldn't believe the overlap is only 4*, and she drives almost like if she was stock.
Old 05-25-2009, 03:40 AM
PREDATOR-Z's Avatar
It has to do with the valve events.
Old 05-25-2009, 09:26 AM
Marc 85Z28's Avatar
That is not how you calcuate overlap.
Old 05-25-2009, 09:45 AM
PREDATOR-Z's Avatar
(intake duration + Exhaust duration)/2 -2xLSA
Old 05-25-2009, 09:46 AM
SweetS10V8's Avatar
Is there anyway we can make that automatically pop-up on people who are making new threads with the word "cam" in it????
Old 05-25-2009, 09:55 AM
streetassasin's Avatar
I almost made that mistake. I was gonna get the asa cam but ended up with a ms3 that I might sale so I can go with a custom predator cam
Old 05-25-2009, 10:28 AM
BlueGoat06's Avatar
Opps, my mistake, it's (((Intake duration + Exhaust Duration) /4)-LSA)*2
Old 05-25-2009, 10:34 AM
BlueGoat06's Avatar
And this is how a TSP 228R sounds at idle with a little tuning
she starts with the factory GM idle speed, then as she warms up, you can tell how the lope comes alive, great power everywhere, and excellent driveability, even idling like that. i can make the car move forward with just the clutch like a stock cammed car.
http://www.youtube.com/watch?v=EhiW1kfhAug
Old 05-25-2009, 03:44 PM
PREDATOR-Z's Avatar
Here is a sample of a properly balanced RS cam combo:230/228 .612/.588 110-1LSA
First graph is cam only C5 (853heads, M6, basic bolt ons)
Second graph is same car with addition of good heads (Cartek 4X) and 90/90
Look at the Trq below curve on 2nd graph 400lbs at 3.5K rpm (yes it is a 346cid )
Attached Thumbnails Cam lope question.... reverse split!-rmtt-camonly.jpg   Cam lope question.... reverse split!-rmtt-hc-90.jpg
Old 05-25-2009, 05:02 PM
rmtt's Avatar
And I am enjoying every minute of it!! Plan to port the Fast and add an electric water pump in the future.
Old 05-25-2009, 06:39 PM
PREDATOR-Z's Avatar
Popcorn idle of RS cam with proper valve events. 8*overlap
http://www.youtube.com/watch?v=LpU-CC5OOM0
Quick Reply: Cam lope question.... reverse split!
