In middle of cam swap.....Getting ASP off?
Old 11-07-2003, 10:42 PM
John02SS's Avatar
Default In middle of cam swap.....Getting ASP off?
I don't have the correct size boltsfor the puller to the get the ASP pulley off. I have 7 and 8 mm bolts and one is too big while the other is too small. What size bolt is it? Everything else is off, including rockers and I'm hung on this damn pulley. Thanks guys!
John
Old 11-07-2003, 10:49 PM
Tally TransAm's Avatar
im not sure what size bolt it is
but i know with a 3 jaw you can attach the jaws to the ridge between the main belt and the ac belt and pull it off from that
dont know if that helps though
Old 11-07-2003, 10:55 PM
Classic's Avatar
Um, I wouldn't suggest using a 3 jaw puller - you could end up breaking the pulley - not good.
I just used the bolts that came with the OEM puller kit I got from Autozone - worked just fine for me.
Old 11-08-2003, 12:14 AM
2xLS1's Avatar
The holes are not metric. They are tapped 5/16 - 24. That is a 5/16 fine thread.
Old 11-08-2003, 01:16 AM
John02SS's Avatar
Thanks 2xLS1! That is what I needed. I'll go pick some up tommorrow.
