need part numbers for 408 rotating assembly
Hey guys. I need part numbers for the crank and rods for a 408 cubicinch stroker, using the 6.0 block. Eagle, scat and compustar would be great. Im not sure where to look to get the part numbers. Also what pistons do I get?? Sorry, this internal engine stuff is new to me.
LS1Tech Sponsor
Mostly sponsors such as us will have a kit listing that will include all parts necessary for a rotating assembly.
We normally run scat as our standard line and callies compstar as the upgrade, with any other manuf you can imagine inbetween or well above the cost.
They will run from $1899.95 up. If you want it balanced by us, then include $200. The rods you will be looking for are normally a 6.125 rod. either small journal or large to fit the crank.
The crank will be a 4" LS crank to fit your reluctor wheel style. Make sure to match rods with crank, ie small rod journal or large.
Our price includes the crank, rods, pistons, rings, and bearings needed.
PM me if you need any more info on what we may have avail or any more questions
