More than a Newbie cam ?
Old 06-26-2009, 12:37 PM
3+3Crawler's Avatar
Default More than a Newbie cam ?
I posted this in the newbie section and maybe I should have posted it here?
I'm sure this is simple basic info but I haven't managed to find it in a couple exhaustive searches..
Thanks for looking... Jeffhttps://ls1tech.com/forums/new-ls1-o...-317-head.html
Old 06-26-2009, 12:50 PM
PREDATOR-Z's Avatar
You'll need 02+ LS6 springs, and aftermarket 7.425 pushrods (smaller base circle on cam). That is all.
All else is interchangeable.
Old 06-26-2009, 06:23 PM
3+3Crawler's Avatar
Thanks for the info.
Whats the stock length of a pushrod?
Also , is there a year when GM switched base circle dia. or was it a LS6 on performance engine thing ?
Old 06-26-2009, 06:28 PM
conan's Avatar
Stock length push rod is 7.4".
Old 06-26-2009, 07:40 PM
3+3Crawler's Avatar
Damn , .025 makes that much difference in hyd. lifter motor?
I kept seeing the "..7.4".." and thought people where generalizing talking about the 7.425 P-rods I need to run the late ls6 cam in my LQ9.
Thanks, Jeff
Old 06-26-2009, 11:19 PM
conan's Avatar
Thanks, Jeff
You can buy a adjustable push rod length checker... And yes it does mean the differance between a smooth valve train and a noisy sewing machine valve train.
http://www.thunderracing.com/catalog...&vid=3&pcid=17
