N-Motion timing chain sets... any bad reviews on them?
How do I change this text
I need an adjustable timing set. just wondering if anyone is running N-Motion. and if anyone has heard anything about them....
They are the private label of the JP Performance timing set. The crank sprocket is induction hardened, the cam sprocket is not. Timing chain is a Rolon. Personally, I prefer the Cloyes Hex-adjust because once you set up the degree wheel and find TDC you can still adjust the cam timing whereas with the timing set that has the adjustment in the crank sprocket, you have to remove the degree wheel to make a change and then start over again.
