Bad miss under light throttle just after startup
Old 07-09-2009, 11:06 AM
mvvette97's Avatar
Default Bad miss under light throttle just after startup
It's a 2000 trans am. It's heads and cam setup. i have almost new plugs and wires so I'm sure that isn't it. After I've been driving a while if I pull in the store or any place and shut the car off and let it sit for 10 min or so is when it does it. It will start back up and idle and run fine but when I go to take off under light throttle it feels like it drops 3 or 4 cylinders. When it does this I will just shipt to 2nd gear and it still does it. Then it will come out of it by the time I shift to 3rd and the rest of the time it runs great. I'm not sure but it almost seems like it is doing this when changing from closed loop to open possible. It doesn't do it any other time only when ya first take off after a hot start. It doesn't have any codes either. What should a guy check?
