Trex help
Old 07-10-2009, 04:09 AM
ItalianoHeck's Avatar
Default Trex help
What all would i absolutely need to run the Trex Cam in my M6 WS6 ??
Also i have a set of AFR Heads will fly cutting the pistons do any bad ??
Really appreciate the help guys
Old 07-10-2009, 09:29 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
The AFR heads have a little bit more p/v than a stock head so that should really help you. You could check p/v where your at & then decide if you need to cut the pistons.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 07-11-2009, 05:06 AM
Thank's im going to call you guys and that way i can figure everything out and what all i need to run the Trex Cam the right way is that ok
Old 07-12-2009, 09:13 AM
f-bodyguy's Avatar
dual springs, pushrods, and if your heads are within .010 of stock you wont have to flycutt almost sure......mostly a tune
Old 07-12-2009, 03:35 PM
yea i get that alot if i had too flycut the pistons would that be bad later down the road or it dose'nt mean anything i also heard i would need bigger fuel injectors is it true?
Old 07-12-2009, 04:30 PM
LS1-NAVY's Avatar
prob cause u have heads and a cam also might want to look into some 4.10 or around there for gears, also do u have a ls6 or fast intake? either will work just wondering.
Old 07-13-2009, 09:55 AM
f-bodyguy's Avatar
flycutting just means u are cutting valvereleifs in your pistons witch i beleive u have to take the pistons out of the motor to do so....with u would be better off buying pistons with v/r precut...so to nswer your question it wouldn't make a diffrence down the road and im pretty sure your injectors will be fine they will just bump the injector cycle up when they tune...
Old 07-14-2009, 05:53 PM
Thanks bro i appreciate all the help
Old 07-14-2009, 08:13 PM
SOMbitch's Avatar
https://ls1tech.com/forums/generatio...ing-tools.html
Hope this helps. Note pistons in motor......
