port matching a FAST 90 to AFR 225 heads
hey there
I noticed that the FAST intake port is longer than the port on the AFR heads by like .150 or 250 what is the normal soultion to this problem:
A. port match the AFR heads to the FAST intake port
B. add JB weld to the Fast and match it to the AFR heads (I am not sure about this I did read something online where it was done but sounds scetchy
port match the intake to the head, {dont worry bout the bottom} that much, port the sides and top, thats what i did,, worked great 4 me.... on the top make sure you stay away from the injector holes good luck
