Anyone know anything about this cam.
SPAM HUNTER
A buddy of mine pulled it out of a LS1 GTO at his work.
Numbers on it are as follows
3725R/3655r
HR116 +4
J1954-06
This is all i know, any help would be appreciated.
Dustin
3725R/3655r
HR116 +4
J1954-06
Dustin
Intake is 230° @ .050 .592 lift (1.7), XER lobes. "most aggressive hydraulic roller profile to date"
Exhaust is 244° @ .050 .595 lift (1.7)Xtreme RPM high lift lobes.
LSA is 116° with 4° advance ground in.
What are the engine specs this cam is being considered for?
Displacement(346?) Heads/porting? Intake manifold? etc? Valvetrain? rpm range desired?
Why did he pull it out?
Jon
SPAM HUNTER
Comp Hydraulic roller:
Jon
Jon
I am freshening up a 6 liter new flat top pistons, rods, bearings, with some 243's, im am undecided if i want WCCH to just go nuts with them, or just have a minor port job, its going to be a pretty much DD'd street motor, so i just want a solid setup, no need to go over the top, but that is a HUGE cam compared to the one i had spec'd out.
Im looking for more of a torque cam, yet still all around. I have pat. duals so .650 is capable but not needed. He pulled it out of a car at his work. He put it back to stock before they put it on the used car lot.
Dustin
