A few questions... 5.3 into 98 Trans AM
Old 08-01-2009, 11:20 AM
Restricted User
1BAD_LS1's Avatar
Default A few questions... 5.3 into 98 Trans AM
What are the differences in the 5.3L from year to year? Is one better than others? ect....
Do I have to cut my K-member to get the 5.3L to fit in my 98 Trans AM?
I should be able to connect my ls1 computer to the 5.3 correct?
Thanks for the help guys!
Old 08-01-2009, 04:49 PM
blackLS1m6's Avatar
The only oil pan that will fit is your f-body pan and yes your ls1 computer will work with your 5.3
Old 08-01-2009, 05:03 PM
nastychevelle's Avatar
i believe 04 and up have better pistons and no you dont have to cut the k member just use your ls1 oil pan and pickup
Old 08-01-2009, 05:36 PM
Vicinity's Avatar
I believe the 5.7 and 5.3 are the same size physically, so it should fit just as your 5.7 did.
Old 08-01-2009, 10:11 PM
pasadena'sfastest's Avatar
yea just change the oilpan.. i got a 5.3 in my 01 camaro
