Combustion chamber size?
LS1Tech Premium Sponsor
They are 64cc out of the box before additional milling. That will net you about 10.7:1 with a GM MLS head gasket. You could run a .040" Cometic gasket keep them at the 64cc chamber and net about 11.0:1 static compression. That'll be nice for the extra power from the compression as well as the tighter quench (helps to ward off detonation.)
Let me know if I can help. We typically keep a few sets of the TFS heads in stock and ready to ship, and offer price matching
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
What gasket are you planning to run?
__________________
Tough Mudder
I left mine at 64cc. I've read that the gains from increasing the compression are often offset by a reduction in flow. And there was also the time factor. I was ready to get on the road!
