Ls6 intake swap
Old 08-08-2009, 03:47 PM
dark ws6's Avatar
Default Ls6 intake swap
I just brougth a ls6 intake with the fuel rails and injectors that come off a '04cadillac cts-V. my questions is if I can do a direct swap using the injectors nad fuel rails? Are the injectors the same as my ls1's? All my emission system has been removed and my computer tuned so I dont have to worrie about the cover plates.
Old 08-08-2009, 09:12 PM
02*C5's Avatar
You are going to have to make sure that the o ring kit is the correct one. You can fit just about any injector in the LS manifold the o rings make all the difference. They are either right or wrong, and you'll know fast enough. The injectors are not the same as the ls1, but the flow rate is different so you will have to re tune. If am wrong some one will correct me soon enough. Oh if they are the CTS V fuel rails you will have to get a new fitting for the fuel feeding line.
Old 08-08-2009, 10:08 PM
dark ws6's Avatar
I got the complete intake with fuelrails and the injectors together, do I need to change the O ring from the injectors?Where can I get the new feeding fuel line?
Old 08-10-2009, 07:37 PM
LS1-450's Avatar
Ask your injector question in the tuning section to find out whether or not they are the same flow rate. If not, & I think that02*C5 is correct, then the tune needs to be calibrated for the different flow rate of the Cadillac injectors. Because the injectors came mounted on the intake, you don't need to worry about the "o"-rings. As for the fuel line fitting. Ask what part number is needed for a Cadillac LS1 intake fuel rail fitting, in the fueling section. You will find the answers in the noted sections. Also, a mail order tuner like (LS1TECH sponsor, FROST) will be able to change the PCM software for the different injectors, once the difference has been confirmed. Hope this helps & Good-luck.
