LS7 lifters good for my application?
Running an 01 ws6 my ls1 just blew a cylinder and going 383 stroker kit with epp cam, sts kit t67 fmic. forged callies bottom, valvesprings, chromoly rods, polished heads.
LS1Tech Premium Sponsor
What springs (or rather what pressures) are you going to run? How aggressive is the camshaft?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I have the dual golds, thinking about shimming them??. running epp fi cam
Cam specs are:
Dur @ .050 232 int 240 exh
Lift .595 int .608 exh Lobe Sep 115.0
All other parts getting from you as you guys gave me the best quote this is a in the process build just trying to put the big picture together on paper first. Would you be the person to talk to about some other questions on the build?
Cam specs are:
Even once you shim those springs, there isn't going to be so much spring pressure that it'd be problematic with a new LS7 lifter. Be sure to check your swipe pattern, installed heights, lifter preload, etc to ensure safe and trouble free operation!
__________________
