What cam do i go with?
Old 11-24-2003, 05:58 PM
fash00's Avatar
Default What cam do i go with?
346 Agostino Racing Engines built shortblock
Ross Pistons
ARP rod bolts and ARP Main Studs
Total Engine Airflow Stage 2 5.3 Heads 2.02/1.60 (flowed 301@.600")
ARP Headstuds
Comp Cams XE-R 232/236 595/602 114
Whisper Lid
SLP 85MM MAF
LS6 Intake
Crane Lifters
Comp Cams Pushrods
Exhaust:
SLP Long Tubes (swapping to kooks soon)
Off Road Pipe
Stock WS6 Exhaust
Qtec Electric cutout
Drivetrain:
Ram 980
Mcleod Adjustable Master cylinder
New updated slave
T-56 tranny
GM 4:10s in a 10 bolt swapping to 9 inch soon
Old 11-24-2003, 06:03 PM
jrp
SN95 Director
jrp's Avatar
whats wrong with your current one? consider the g5x2 or x3?
Old 11-24-2003, 06:12 PM
tim99ws6's Avatar
yea, that's also a pretty high lsa, why did you do that? streetability?
yea i think you're cam right now is awesome, except for the lsa.....good luck.
Old 11-25-2003, 12:46 AM
fash00's Avatar
want more power it is a daily driver so keep that in mind what would you go with
Old 11-25-2003, 12:54 AM
jrp
SN95 Director
jrp's Avatar
like i said, the x3 on the 114. or why not just go a custom grind, i think that'll be a better bet for your setup then an off the shelf cam.
