Anyone running Trick Flow 7.350" pushrods?
I think I may need to go to shorter 7.350" pushrods with the new heads I'm going to be installing. The heads are milled about .040" - .045" I think, and the 7.400" comp pushrods I have now might be too long. If that's the case, anyone see why I can't run these PR's? They are about $35-$50 cheaper than the Comp version most guys run.
From Summit's catalog:
TRICK FLOW chromemoly pushrods (P/N TFS-21407350)
5/16" diameter, 4130 chromemoly, one-piece design, heat treated.
Price: $84.50
Thanks,
Craig
Price: $84.50
Thanks,
Craig
Yes, I have the Trick Flow push rods and mine are 7.35's. I got mine from TEA when doing my head and cam package. Based on what my heads were milled and cam base circle they were dead on the mark exactly like Brian said they would be for my application.
Call TEA they should be able to help you with this.
You might want to get an adjustable push rod to determine the exact length you need.
