I am buying a new set of AFR heads the 205cc intake runner size and am undecided on which size CC to go with. Will the 64 cc CC be to high of a compression ratio to run a 150 shot of n2o?
Nitrous isn't exactly like boost, as long as you aren't at your compression limit (like 12:1) you shouldn't have any unforseen problems with a correctly set up system.
