Valve spring pressure questions ??
First has anyone (themselves) pressure tested Comp 918 springs?
If so what pressure did you get at a 1.8" installed height? And what installed height are you running with them to give you what seat pressure?
Secondary question: Does anyone know the stock LS6 intake valve weight? and the stock LS6 spring pressure on the seat & installed height?
I'm looking for actual numbers measured here, not trying to figure out how to do something okay. I'm just trying to verify info against what others have measured.
For those that have any input on this, Thank You!
Valve Weights
Hi,
02 LS6 valves & springs measured data:
intake 76 grams, exhaust 63 grams
Valve springs, 90/95 lbs seat @1.800 with 345/360 lbs/inch rate
Chevy manual gives 90@1.8 & 375
LS1 valves
Intake: 99 grams, Exhaust: 86 grams
Stock LS1/6 retainer 11.2 grams, Comp Ti 7.2 grams
28.36 grams/ounce
Good luck,
Steve
LS1 valves
28.36 grams/ounce
Good luck,
Steve
Originally Posted by SNW Vette
Hi,
LS1 valves
28.36 grams/ounce
Good luck,
Steve
LS1 valves
28.36 grams/ounce
Good luck,
Steve
Anyone else test the 918 springs?
Originally Posted by LASTLS1
Give me the the installed seat height and the compressed height and I'll give you the pressures.
1.8" seat
1.23" compressed.
thanks!
