which cam should i use
Old 10-18-2009, 07:46 PM
bowtieguy72's Avatar
Default which cam should i use
ok guys ive got a comp grind cam with specs 238/240 605/609 lift on 112 lsa
and i also have a lingenfelter gt7 cam. ive got a 6.0 lq4 ill be putting in the silverado with a p1sc procharger. my question is which cam should i use for the most power i know the first one should make more hp but will it work ok with the procharger.
Old 10-18-2009, 08:02 PM
TransAmcoupe98's Avatar
I'm not sure about the specs on the GT7 cam, but the 238/240 on a 112 is a no go. You will have boost bleedoff with the Procharger.
