best CR for TSP Torquer v.2
10 bolt took a crap so the car will have some down time. While its down I am looking at getting the heads milled but have a few questions.
What is the most I can mill my heads without having PTV clearance problems?
Is there a formula that can be used to figure PTV clearance out?
LS1Tech Premium Sponsor
If you've got still got the stock valves in the heads, and you didn't mill them already, you should be able to hit them about .020" or so comfortably with that camshaft
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
