will I need bigger injectors for ported heads?
depends on the hp also. You never want your injectors to be running higher than 80% duty cycle and they pretty much go static at 92% of duty cycle. Look at the application how much hp you are going to be putting out and then choose correctly.
Here you go it helps in choosing an injector for hp needs;
http://www.injector.com/injectorselection.php
