Is my cam ok PTV wise with my 5.3 heads?
Old 11-15-2009, 07:41 PM
drewwrxrogers's Avatar
Default Is my cam ok PTV wise with my 5.3 heads?
Is this combo ok....
5.3 heads with Patriot Gold Springs and retainer kit....
And this NX3 Comp Ground Cam..... *Speed10030 LS1/LS6 Stage 3 Cam SEAT 292-298, @50 235-239, LOBE LIFT .353-.341, VALVE LIFT .600-.580, C/L 112
7.4 pushrods
Any and all ideas heard..I wouldnt think it was a problem but double checking!Thanks!
Old 11-15-2009, 08:59 PM
Clearances:
Intake (P): 0.025-0.066mm / 0.001-0.0026"
Intake (SL): 0.093mm / 0.0037" Max.
Exhaust (P): 0.025-0.066mm / 0.001-0.0026"
Exhaust (SL): 0.093mm / 0.0037" Max
Oil Seal Installed Height = 18.1-19.1mm / 0.712-0.752"
(Measured from VS Shim toTop Edge od Seal Body)
Valve Stem Dia. (P): 7.955-7.976mm / 0.313-0.314"
Valve Stem Dia. (SL) 7.9mm / 0.311 Min.
Valve Spring:
Free Length = 52.9mm / 2.08"
Pressure (Closed) = 340 N @ 45.75mm / 76# @ 1.80"
Pressure (Open) = 980 N @ 33.55mm / 220# @ 1.32"
Installed Height (Intake) = 45.75mm / 1.800"
Installed Height (Exhaust) = 45.75mm / 1.8"
Valve Guide Installed Height = 17.32mm / 0.682"
(Measured from Spring Seat Surface to Top of valve Guide)
Roller Lifter Dia.:17.78mm / 0.700"
Valve Material: Stainless Steel, Hollow Stems, Na filled Exhaust
I have been looking for something that may help...found this and I think it may be usefull but need some help with an answer.
Old 11-16-2009, 09:35 AM
I could really use some help on this...I am waiting til a little later to call comp and ask them if everthing should be ok but Id like to hear from maybe somebody with a similar setup. Thanks.
Quick Reply: Is my cam ok PTV wise with my 5.3 heads?
