Melling HV vs Ported LS6 oil pumps
i'm about to buy my oil pump for the new 6.0L build and i don't have a clue which to go with. i can get the melling for about 40$ less than the ported ls6 pump, but i can't seem to get a straight answer on which one is better? the ported ls6 pump in question would be a TSP unit.
thanks for any input!
ive heard the hv pumps will suck the pan dry at high rpm's
i had a buddy kill a h/c/i ls1 a while back and he swears it was the oil pump pumping too much volume
he said he will never use anything but a stock ls6 pump again
so shawn that sounds like to me that you like the melling for all out situations where you don't want a failure...and if i can get that one cheaper than the ls6 pump, seems like i i might be better off with the melling.
any cons to the melling? cost more HP to turn it or anything?
edit: i just saw your post, yikes, it dried the pan?
1 Post
why is it that i hear all these pan gets sucked dry stories after i got my HV pump. anyways i paid 105 bucks shipped from lingenfelter.com for a high volume oil pump, 30% more flow and stock and high psi spring and o rings included
Still, I spun a bearing at 7k on the stock ls1 pump and I keep my engines a half quart over. I doubt I'll be regretting the decision since I already had 1 oil-related failure.
If oil is like boost(and I know they're not I'll get there in a second), pressure (PSI) and volume (CFM, or quarts/min I guess in oil terms) are only somewhat related. It's because its a high volume oil pump that it starves the pan, not because of the higher pressure spring. Am I wrong in assuming that? Except they're NOT alike, oil isn't compressible and air is. Someone help me out here please.
I've run both melling and tsp. My current motor has the Melling HV with a stock oil pan. however I also run a 6.0 truck filter which is bigger and an extra quart of oil and daily drive the hell out of the car all spring summer and fall and no problems. My tsp gave me no problems but had to ditch it in the new motor because it was packed with metal shavings from a lifter knocking my Cam out.
As mentioned the pressure isn't related to the volumetric flowrate in this case considering that our oil pumps are basically positive displacement pumps which means they pump the same volume regardless of pressure. A ported oil pump simply reduces the flow restrictions in the inlet/outlet of the pump to make it easier to pump the oil thus saving you 0.01 HP
Look at my sigs and I just run a stock ls6 oil pump and have no problem. My tuner say he doesn't like the ported ones and he's seen more problems out of a ported ls6 pump and hardly ever has a problem out of the stock ls6 pump.
Im running the Melling M295 and it works great. I have watched it with a mechanical pressure gauge. Its about $105 from advance auto. Its a Melling stock replacement pump.
