How high could I bump up my rev limiter/shift points?
Old 01-31-2010, 02:21 PM
Mr.Slow's Avatar
Default How high could I bump up my rev limiter/shift points?
I got my cam installed(sig) along with Comp Cams 26918 Valve Springs, and Comp Cams Chromoly pushrods. I already know the new cam is making enough power past 6000 rpm to justify bumping up the shift points and rev limiter, I'm just worried if the valvetrain can handle it.
I only have a printout of the dyno, but to a little under 6200 rpm(it was bumped up a bit), it doesn't seem to drop down at all.
