ls1 to ls6 head parts crossover
Ok so I've got an 01 LS1 engine, swapping the 241 heads for some 243s, one of the 243s has a bad valve guide. My question is whether or not the ls1 replacement guides http://www.summitracing.com/parts/TFS-30600251-1/ will fit the new ls6 valves (hollow core, 8mm valve stem)
also, I only got the springs and rockers, that means i need retainers, locks, valve seals, what else?
That is actually a bronze guide for a Trick Flow head. It is not a stock replacment guide. To answer your question regarding the LS1 and LS6 guides, the factory LS1 and LS6 guides are the same.
Shane
Shane
