Changing to 243 heads, ok to use stock 241 gaskets?
Looking online at Autozone and Napa for gaskets for a 01 Firebird they come up with a graphite gasket that is $30 or so. If you search for a 03 C5 Z06 it comes up with something totally different. The one on Napa is $115 and AZ is $43. Both utilize the same bore but call out for different P/N from Fel Pro.
Did a search on the first P/N ($30 gasket) and found posts saying they were stock replacement but just find it a little odd the C5 LS1 gets a different number called out.
If I go with the first $30 gasket will I be safe with switching the heads? Don't plan on spraying or boosting it, at least with the stock bottom end. On a college budget and every little bit saved helps, otherwise I would just bite the bullet and get the spendy guys.
LS1Tech Premium Sponsor
I'd go with the GM MLS gasket! Thy are under $50 for the pair and will treat you well!
http://www.texas-speed.com/shop/item...d=879&catid=36
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Local dealers don't have the gasket in stock and say it will be a week before I would see them and want $110 a piece.
Probably just going to settle with the Fel-Pro and maybe change it out this summer when I look at doing more with the car.
What's the GM P/N for the MLS gasket? Gave them the P/N from the LS1howto head swap and that is the one they said would take a week.
If only I could get it by tomorrow without having to pay double the price the gasket for shipping.
__________________
