Where to get best price? rods/pistons/bearings/bolts etc..
Im looking for a little help on where to get the best deal for ls1 based rebuild:
- Callies H beam rods 6.125 with arp 2000 bolts
- Wisco/diamond/JE low comp boost pistons stock bore (which best for $$$)
- Main/cam bearings
- Arp main studs/ arp head bolts/ balancer bolt (Do I need an arp balancer bolt or can I get away with the stock GM one)
-All the necessary gaskets (intake,head,oil pan, water pump, front/rear cover etc..) Also for a boost setup with ls6 heads what head gasket should I be using (cometic or reg GM one)???
I got a few good prices/deals so far but they're through seperate sponsers/companies. So I wanted to see if there was a one stop place that i would be able to get all these parts on the quicks and fair/cheep pricing.
I tried searching for good deals/pricing on this stuff but limited info so maybe you all can share some info here.
Thanks for the help everyone
- Main/cam bearings
