eps 236/248 cam
Old 04-28-2010, 09:30 PM
00 black ss's Avatar
Originally Posted by JPH
Leave this profile for your 402/408 your building imo.
i was orignally going to build that big of a motor but the cost is getting up there so im going to have to go with a 383
Old 04-28-2010, 10:55 PM
11 Second Truck Club
MPFD's Avatar
Thats real close to the duration of the custom I'm gonna run in my lq4 with 243's, whats the lift and LSA?
Old 04-29-2010, 12:13 AM
fatmat80's Avatar
Originally Posted by Paint_It_Black
I've got my own custom grind. I call it "the stick snapper." Very similar to Geoff's cam. I was very surprised to see someone else "get it" too.
sounds like a little "*****" envy to me..OOOOHHHHH here comes the "stick snapper" lmfao!!! hows the view from you vantage point..sorry im a former magic stick car myself and thats usually what my competition sees!!!!!
Old 04-29-2010, 12:36 AM
LilJayV10's Avatar
I cracked up when I heard "stick snapper" That doesn't even make sense.
There was that one guy with hot chili cheese dog cam or something like that.
Old 04-29-2010, 01:10 AM
fatmat80's Avatar
Its all a gimic to sell more cams for the companies but for a average guy to "make-up" a custom cam and call it a super cheezy name like "stick snapper" is well you know kinda
Old 04-29-2010, 01:45 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Originally Posted by Nitroused383
Are you serious? Why would you say that
Because its true.
Old 04-29-2010, 04:02 AM
pheer's Avatar
the EPS cams are supposed to be easier on the valvetrain (?) while still making the same power as some of the bigger cams, right?
Old 04-29-2010, 07:46 AM
Paint_It_Black's Avatar
It's got better valve events than a magic stick because I wasn't concerned about it fitting under a stock head (which it won't). It makes more power in the midrange and carries better after peak. It's just better.
Old 04-29-2010, 07:50 AM
Average guy... haha. You don't know me from anyone. I own my own top end modifications business. I port heads, intakes, and spec cams. Granted I just started, so no, you don't know my name.. yet. Look for a dyno with this cam and stock heads in the next month.
Edit: And no, I do not call it a "stick snapper". It's part of a package I only sell with the heads. But I had a feeling calling it that might generate a little bit of talk.
Old 04-29-2010, 08:16 AM
the lift is .624/.621 on a 110 lsa
Old 04-29-2010, 08:26 AM
id really like to order a cam by tommorow morning and still have trouble deciding. so far the options are ms4, one of the 2 eps cams mentioned or the megadeath.goals are 425 at wheels. this is going with a ls6 intake, 1 7/8 lts and stock 243 heads on a 383.compression ratio will be around 11.25-1. what would you guys recommend? im looking for bigger and more choppy then my ms3
Old 04-29-2010, 08:39 AM
  #32
The 236/248 Geoff called the T-Rex killer. It will make more in the midrange and carry better. He said it on this site. He designed the T-Rex so I think he knows a thing or 2 about it. He also personally designed the lobes for the cam. The dude is smart.
Old 04-29-2010, 09:04 AM
  #33
87silverbullet's Avatar
Get the 238/246 cam and be done with it. Period.
Old 04-29-2010, 09:49 AM
  #34
would this cam get me to 425rwhp? and also would it be more choppy then my ms3?
Old 04-29-2010, 10:42 AM
  #35
STAR's Avatar
Originally Posted by orangeapeel
Because its true.
I personally wouldn't use Ed myself(speck my own grinds), but it seems like there are plenty of happy customers with his cams. Any reason why he shouldn't be considered for someone looking for a custom cam?
Old 04-29-2010, 11:03 AM
  #36
In a m6 car Geoff's old Tr 224 grind made 425 rwhp with ease so this one will get there with no problem. As far as chopiness it should be just as choppy or more since it is ground on a 110 lsa.
Old 04-29-2010, 11:50 AM
  #37
fatmat80's Avatar
Dont get your panties in a bunch "Paint it Black" your right i dont know you and i dont think contradicting yourself will get your name viewed in a higher light..you said your cam was not designed to fit under stock heads yet now you are sayin look out for a dyno of your cam under stock heads..I never really bought in to bigger is better but there are big cams like the ms4 and trex that flat out get it done, cant argue with real world results now can you?? But i am sure you will..Here is a video of a freind of mines car at the track in a cam only 02 SS..And yes you guessed it its a trex..I dont have to show you any ms4 cam cars TSP has done enough of that dont you think??? ..
http://www.youtube.com/user/deanh8#p/u/24/_7g_ARUDVSs
Old 04-29-2010, 12:08 PM
  #38
MPFD's Avatar
My cam has three degrees less exhaust duration, but real close. I think I'm gonna throw mine in with some P&P heads first of next year...
Old 04-29-2010, 01:41 PM
  #39
do you think that cam is to big for a 383 or it will be good?
Old 04-29-2010, 03:06 PM
  #40
11.63? I've seen bolt-on cars run faster. That is not impressive to me, sorry.
Yeah, they are big cams. That's why they have made power before. They're old tech. The intake lobe on my cam is smaller than both the t-rex and ms4 by the way. And I'm not sure how I'm contradicting myself. My cam won't fit under stock heads. I have to flycut, but it will still be run with stock 241's. I could really give a **** what people on this site think about me. This site is junior high in the world of racing performance. I don't drink the kool-aid like you do. People can listen to me and go fast, or not listen to me and maybe go fast. it's up to them, doesn't bother me either way.
Quick Reply: eps 236/248 cam
