Another Ticking Thread
Ok so I had been doing a few donuts in my 01 m6 vette, developed ticking got worse over time. I ended up pulling valve covers replaced all rockers and pushrods with new factory originals and replaced girdles too. Never had needle bearings or metal shavings in the oil. Car seems like it has very slight miss, performance is down a little. Ticking is from pass side valve cover gets louder when it heats up not too loud at intial startup it does follow the RPMs up and down. My question is does this sound like bad lifter or maybe spring? Thanks alot for any help
Its a vette of course oil pressure sensor went out, under the intake havnt changed it yet ugghh - thanks for ur help, do you know what i should look for with a broken spring?
