stroker 383 crank with stock rods & pistons
Old 04-27-2010, 04:20 PM
SLOC5LS6's Avatar
Default stroker 383 crank with stock rods & pistons
Has anyone ever done a stroker 383 crank w/ stock rods & pistons on a 346cid? Any benefit?
Old 04-27-2010, 04:24 PM
02 BLK WS6's Avatar
No because it won't work. When using a longer stroke crank, you have to use shorter rods. I don't know why a person would want to use stock pistons for anything other than a stock engine.
Old 04-27-2010, 05:10 PM
bww3588's Avatar
actually, with most stroker cranks, you use longer rods...the length comes off the pistons. you use pistons with a shorter CD.
Old 04-27-2010, 05:24 PM
Lambert695's Avatar
The only thing that would do is waste your time..
Old 04-27-2010, 08:58 PM
RARON455's Avatar
Yup I have the callies compstar, 6.125 length rods, with wiseco pistons designed for that length rod.
Quick Reply: stroker 383 crank with stock rods & pistons
