Will ls6 heads fit on a 5.3 motor?
Old 01-10-2004, 12:03 AM
Okie02's Avatar
Default Will ls6 heads fit on a 5.3 motor?
Well i bought some stage 2 patriot ls6 heads to put on a 6.0 im buildin but i have decided to sell the 6.0...i know the heads will bolt to the 5.3 but the exhaust ports are different on the heads i think...i was just wanderin if my headers would bolt up to these heads or not? thanks
Old 01-10-2004, 12:09 AM
jrp
SN95 Director
jrp's Avatar
there should be no problem with the headers bolting up. the ls1/5.3's have an oval shaped port and the ls6/6.0 have a D shaped port.
Old 01-10-2004, 12:14 AM
Okie02's Avatar
ok cool...thanks
Old 01-10-2004, 07:09 PM
U LUZ's Avatar
yes it will i just did a 5.3 with ls6 heads a month ago runs good ...you better mill them at least .50 or you will not very high compression at all.......
Quick Reply: Will ls6 heads fit on a 5.3 motor?
