Comp 26926 vs. Patriot Extreme Duals
Valve springs are one of the main things you don't want to skimp out on when picking them. Depending on your cam, the patriot golds may work just fine if setup properly. I'm running comp 918 springs on my build but I'm running lightweight valves and titanium retainers. IMO pick the best spring that you can afford.
LS1Tech Premium Sponsor
Checkout the PRC valve spring kits, we use to run the same spring as the Patriot kits, but a recent redesign has helped us to now offer a spring with a much longer expected life & much greater resistance to pressure drops. One of the issues we had with the old spring was camshafts with higher lift could sometimes make the old spring shrink, the new PRC springs use a much improved material to resist this issue.
The Comp kit is nice, but priced something close to $500!?!? The PRC .650" kit is well under $300 & the .675" EHT kit is only slightly higher!!
http://www.texas-speed.com/shop/item...d=173&catid=48
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
