JP performance timing set...do I need spacers?
Old 06-02-2010, 08:38 PM
STFU racing's Avatar
Default JP performance timing set...do I need spacers?
i have a JP performance timing set part # jp5628T and I'm putting it in my ls1...i bought it from someone here on ls1tech...
i have the double roller cam piece/crank shaft piece and a bearing...I noticed some timing sets come with spacers...do i need one for my application???
thanks in advance
Old 06-03-2010, 09:47 AM
Jon@Texas-Speed's Avatar
If it is a double roller cam you will need spacers. You might call the guy you bought it from and see if he still has them.
Jon
Old 06-03-2010, 02:50 PM
More specifically as i've done more research I've figured out that timing chain i have is for a ls7 motor....will it fit on an Ls1?
If so does it need any spacers for the oil pump?
any help is appreciated.
Old 06-03-2010, 03:41 PM
I believe it will fit without a problem. The LS1 doesn't care about the cam signal on the front and as long as it is a 3-bolt upper cam gear it will bolt up. However you will still need spacers for a double roller using it on a LS1.
Jon
Quick Reply: JP performance timing set...do I need spacers?
