Weird low oil pressure at startup... please help :(
This started today after racing it at the strip yesterday. It's my friend's 1998 C5... He has only tested it around 4 times since it's a low oil pressure issue.
When he starts the car, the oil pressure gauge will take a while to go up instead of going up almost instantly like normal. It stays at 0psi for a short while... the longest it has stayed at 0 psi has been almost for 15 seconds then it went up...
This only happenes after the car has been sitting for a whlie. If he starts it right away after turning it off, it will go up like it always does. He has only tested it with a warm engine since the problem started today. He didn't notice if it was working normally this morning.
He's using 5w 50 full synthetic oil and K&N oil filter... he did an oil change a couple of weeks ago and didn't have any issues until today, the day after racing it.
Any ideas what could be causing this?
