PP Stg2 5.3 vs PP Stg2 5.7 big diffrence in HP?
Im currently looking for cylinder heads for my car...
I was going to get the 5.3 Stg2 heads then I found out about the good deal on 98style stg2 perimeter bolt heads....
I know the size of the combustion chamber on the 5.3 raises compression about half a point over the stock LS1 heads.
How much HP diffrence would the compression diffrence actually amount to.
If im only losing around 5-10rwhp I can spend the diffrence in price on some other parts to make up for it.
Another plus is not having to change the valve covers or worry about the coilpacks.
LS1Tech Premium Sponsor
As mentioned, the 5.7L perimeter-bolt heads are hard to beat for the price! If you're running a 224/224 cam or smaller, you could mill the heads .030" to bring the compression up to right at 10.5:1. However, this will limit your ability to upgrade to a larger camshaft in the future without having to cut valve reliefs in your pistons.
Let me know if you have any other questions or if you'd like to get a set of Patriot cylinder heads on order.
Trevor
Texas Speed & Performance
Trevor
Originally Posted by XFiveLiter
Trevor, I have some PP 5.7s milled .050 (not installed yet). Do you forsee any PV issues w/the cam in my sig? Also, how much compression would this give me? I was hoping for 11:1. thanks
Let me know if you have any other questions.
Trevor
