Oil Pressure?
Oil Pressure?
This is in my rock crawler. The pressure seems kind of low. Are these gauges usually fairly accurate? I'm probably going to install a mechanical gauge on the fitting above the oil filter to get a little more peace of mind.
http://www.youtube.com/watch?v=n1AGNwJ1r0c
Is that a mechanical gauge in their now? Is the oil run right into the back of it? Air in the line will cause it to read low. A gauge at the filter would cure any doubts. As long as everything is mechanically sound you can always put a bigger spring in the pump for more pressure.
dont feel bad my car is doing the same f'ing thing, almost the exact pressure, i replaced the o ring then the pump then another o ring, and still the same, now i gotta go and get an oil pressure gauge to see if mine is messed up
That is an electronic gauge in the video. I believe the sending unit is autometer adapted in the stock ls1 location at the rear behind the intake.
