TSP H/C Fuel System Upgrade?
Old 07-11-2010, 07:30 PM
1stLS1Z28's Avatar
Default TSP H/C Fuel System Upgrade?
Going to be installing a Heads and Cam package into my 02 Z28 M6 soon. Lot's of searching and based on price and performance goals I am looking at what TSP has to offer. Either 2.5 LS6 or 5.3 heads with something like the Tsunami cam. I was wondering if I need to expect to upgrade the fuel pump, injectors and or fuel rail when installing those heads and cam?
Old 07-12-2010, 06:49 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Put a Walbro pump in it and get some 30 or 36 pound injectors
Old 07-12-2010, 10:06 PM
1stLS1Z28's Avatar
So the stock stuff will not keep up? Do the 30-36 injectors require a new rail? Are these the FORD injectors people are using?
Old 07-12-2010, 11:37 PM
tberry95z28's Avatar
thats a pretty big cam id probally get injectors youll be pushing the stockers
Old 07-13-2010, 12:36 AM
stryder's Avatar
get some bigger injectors i.e. 30lb red top, 42lb green tops, and a walbro pump. I would also change out the fuel filter while your down there. the ford svo injectors will fit on the ls fuel rail no problem.
Old 07-13-2010, 03:14 AM
Squirts11's Avatar
Injectors? Yes. Hit up FIC, they're a sponser here that'll hook you up for a reasonable price.
Fuel pump? Maybe. You could drop the coin now for an upgrade, or wait until it hits the dyno for tuning to see whether or not the stocker will be adequate.
Old 07-13-2010, 03:59 PM
Z28/2002's Avatar
No they don't require a new rail and yes they are the SVO injectors
