what oil pump & timing chain to go with during my cam install?
Any suggestions/part #'s or links as to what would be a good oil pump and timing chain to go with during my cam swap? I was thinking of the LS2 chain or is the stock replacement suitable?
Thanks
Thanks
Seeing as you have an 02 you already have the LS6 pump, no reason to really change it. Lots of guys here get the Mehling, the ported pumps, etc... I like a nice unopened factory GM LS6 pump. There's been failures related to every pump so I stick with what GM offered from the factory. Sometimes that's the best bet. I use it, it holds plenty of pressure.
As for the chain... answer me this, what cam is going in?
