is the trick flow top end kit really any good? 515hp's!!
Old 08-22-2010, 01:51 PM
dbeach2001's Avatar
I used the kit from Vengeance Racing and it comes with the Yella Terra rockers and TFS 220 heads. The cam is bigger and it made 470hp at the back tires. I also installed a Fast 92 intake, throttle body and 25% under drive pulley. I run kooks long tubes w/o cats through a GMMG exhaust. Sounds killer and makes great power.
Vengeance racing was great to deal with also.
Old 08-22-2010, 07:18 PM
stunna p's Avatar
the vengence deal is on fast is cast. isnt the cnc ported way better??
mo hp's.......
Old 08-22-2010, 10:42 PM
garygnu's Avatar
the 215 cnc tf head is worth 10 more hp.
Old 08-22-2010, 10:55 PM
Detoxx03's Avatar
Much better packages out there
Old 08-23-2010, 02:50 AM
Camaro ss 2001's Avatar
Originally Posted by gyrene2003
anybody running a cam in the ball park of the futral f13?(230"/232" .595"/.585" 112LSA) with a set of the trick flow 220cc heads? I went from like 315 rwhp, cant remeber exactly, to 390 with this cam and have been eyeballin a set of the above heads and i was hopin to get near 430-440 ish or really low 11s, any experience? Sorry to hijack, wish i had the money, id jump on that package in a heart beat!!!
u saying u got more then 75hp just by adding a cam??
Old 08-23-2010, 03:17 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
You say that like its not possible.
Old 08-23-2010, 02:03 PM
CenTex's Avatar
How would that setup be for a daily driver?
Old 08-25-2010, 04:53 PM
gm50cal's Avatar
Thanks Mike C. thinking about it, a newer and bigger block is a better idea than a SC or turbo. now let me ask you this. if i get the package from vengance for m LS1, down the road when i have mroe money, could i upgrade to like a LS3, LS7 block or something using those heads? if so, would it be worth it. meaning would those heads still make good power on a ls3 block or at the level are there much better heads?
Old 08-25-2010, 05:02 PM
Philip@HPE's Avatar
Originally Posted by SOMbitch
There are better cams to run IMO and I also like Yella Terras over the the Harlands....
Another vote for Yella Terras here.
Old 08-25-2010, 09:26 PM
flintwrench69's Avatar
I wouldnt. If I was doing a bigger bore engine its a no brainer to get the L92 or LS3 heads. LS3 heads flow better & are much cheaper than anything. Problem is the LS3s dont fit on a 3.9 inch bore so its 243s or aftermarket castings for best performance on a 5.7.
Quick Reply: is the trick flow top end kit really any good? 515hp's!!
