How much difference between 112 and 114 LSA
Old 08-12-2010, 06:47 PM
Kris Mangrum's Avatar
Default How much difference between 112 and 114 LSA
I ordered a 228r cam with a lsa of 112 on monday so that I could install it and the motor in the car this weekend. Well a mistake was made(it happens) and I was shipped a 228 114 instead. Its killing me and I want to put the motor in this weekend. How much of a difference between the two? This car will never see a track or a strip but will one sound better than the other and will there be a performance difference. I want a noticeable lope.
Ls1
Ls6 intake
Ls6 heads
.040 heads gaskets for around 11:1 comp
Old 08-12-2010, 07:07 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
If you want lope, then unplug a coil pack wire. If you are concerned about how it sounds, then change the exhaust setup. A cam selection should be based on engine performance, not sound or lope.
Sorry, but picking a cam based on how it sounds or lopes is just stupid. If you're worried about how it will impact drivability or power, you probably would have a hard time telling the difference between the two except for on a dyno.
Old 08-12-2010, 08:29 PM
While it may be "stupid" to you, its not to me. I'm looking for a whole package deal. What difference on the dyno?
Old 08-12-2010, 08:45 PM
89 formula350's Avatar
it will move the powerband slightly.. you will still have a lope
https://ls1tech.com/forums/generatio...s-114-lsa.html
scroll down to matt's post if that doesnt show ya
Old 08-12-2010, 09:13 PM
Thanks for the link. I was going to do the 110lsa but they couldn't get it to me by this weekend so I ordered the 112. Hmmmm? What to do.
Old 08-12-2010, 09:51 PM
flintwrench69's Avatar
I got a 228r on a 114 & its got a nice lope to it, my powerband isnt much different than the 112 cam is. The 114 is supposed to be smoother idle but its not as smooth as I thought it would be. Its a great cam with a fairly wide powerband. If you really think you gotta have the 112 then wait it out but the difference in powerbands is very little.
Old 08-12-2010, 10:04 PM
The thing is this car will not be a Daily Driver. It will only be driven to shows, pleasure cruise's, that sort of thing. Thanks for the comments, every bit helps.
Old 08-12-2010, 10:39 PM
69LT1Bird's Avatar
It will also have an effect on PTV. Like stated above, pick a cam for the best performance for your car not for a lopey idle or sound. Put in a toggle switch and kill an injector or coil when you think you want to impress people with the idle.
Old 08-13-2010, 01:17 AM
itsslow98's Avatar
You could always drop the idle 50-100rpms to make it lope a little more. Mine has a nice chop to it, sounds like you made your mind up and want a 112 but are too impatient to wait.
Old 08-13-2010, 01:56 AM
2000RDT/A's Avatar
haha they must have sent it to me. i got my 228r on a 112 in on tuesday lol
Old 08-13-2010, 07:06 AM
The car will do the impressing, with or without me being involved. Its more for me I guess. Thanks guys
Old 08-13-2010, 08:12 AM
UNDER PRESSURE MOD
Like stated, if you really want a 'lopey' idle, drop your idle rpm, or leave it a factory settings and it'll lope, but be prepared for other issues like stalling.
Old 08-13-2010, 11:38 AM
112 is on its way to me
Old 08-13-2010, 12:18 PM
redz_02's Avatar
Look into overlap. This is what determines what you call lope. Lowering your LSA just adds overlap, and makes the power band a little peakier. With an even split cam with those specs, the deference between 112 and 114 won't be noticable. If you want a big lope, you want a big split cam.
Old 08-13-2010, 01:27 PM
02*C5's Avatar
Agreed, the only real time you will notice and that is if you really pay attention is if you are doing a highway pull, Your power band will come in at higher RPMs. Now depending on the cam and the amount of * of overlap will let you know how much lope you are going to get.
Easy way to determine overlap is
int+exh lobe
what that equals to divide by 4 minus LSA and then X2. What ever that equal is going to give you your degrees of over lap.
Most off the shelf cams have an average of 14* to 16* of overlap specially for N/A application. Positive over lap will give you lope, negative overlap will not. FI cams have small lobes and are set between a 115-117 LSA Most FI cams will give you negative *s of overlap and 0 lope. That is the reason if lope is that important to go with a cam with an LSA between 110 - 112 and bigger lobes (ie 22X/23X or 23X/24X) The Comp 23X/23X series are great for that.
Old 08-13-2010, 02:10 PM
The cam I bought is a 228/228 with 112
228+228= 456
456/4=114
114-112=2
2x2=4 degrees of overlap. Is that right? IF so its way under the normal amount you gave me. Thank for the info.
Old 08-13-2010, 02:19 PM
Super Speed's Avatar
The 228 will Lope but it won't be any where close to say a ms4 or ms3 in terms of lope
Old 08-13-2010, 03:41 PM
02*C5's Avatar
228+228= 456
456/4=114
114-112=2
Yeah 4* of overlap is not much if anything at all, your not going to get that lope you're after. You can have the installer degree your cam up to 4* of advance and that will change the lobe events and get you a little more TQ under the curve and a little more lope. That's about the best I can tell you.
good luck
Old 08-13-2010, 03:55 PM
MikeZ06402's Avatar
Good to know info
Now that explains why I can get this puppy to idle better than I expected. If my math is correct I have -5 degrees of overlap. So is that to say I have no overlap with 5 degrees of seperation between the lobes? Either way I like it and still have plenty of power.
Old 08-13-2010, 04:11 PM
02*C5's Avatar
Originally Posted by MikeZ06402
Good to know info
If your avatar is right you can't compare a 402 and a 346 period its apple and oranges. Your displacing way more air and fuel mixture and you can owe overlap and still have more hp.
Quick Reply: How much difference between 112 and 114 LSA
