Forged Piston to bore clearance?
Old 08-22-2010, 09:33 PM
ABQ99TA's Avatar
Your pistons will rock back and forth a little. That is how you messure for out of the hole @TDC.
This is something that should have been checked during the biuld I wish you luck man I hope it all gets worked out. I have met you, I hooked you up with the sparkplug wire. GL keep us posted.
PS you said your bore was 3.912 your getting close, if your pistons were ordered for a(stock)LS1 that is allot smaller.
Old 08-22-2010, 10:28 PM
89L98T56's Avatar
Oh yea DansAm right?? Hows your car coming? Yes unfortunately I decided to trust the machine shop guys and did not double check their work when I got the shortblock back. Yea I measured the bore at 3.912 and the pistons at 3.900. That's a lot of gap.
Old 08-22-2010, 10:35 PM
ABQ99TA's Avatar
Car is running fine but I have not had it down the track yet so we will see. Sorry to see your problems. I hope you get taken care of. If you need me to talk to anyone in ABQ let me know.
Old 08-22-2010, 10:51 PM
89L98T56's Avatar
Alright man I might get you to round up the gang and take over performance plus haha!
Old 08-23-2010, 12:46 AM
KCS
Moderator
KCS's Avatar
Originally Posted by 89L98T56
I have built a few engines, but I am not an engine builder. I used a dial indicator and micrometer. Measured in the middle of the cylinder.
Where did you measure on the piston? You need to measure at a specific point on the piston to get the true diameter, since the side profile is more of a barrel shape rather than a straight cylinder.
Mahle pistons are a 4032 alloy so their suggested piston to wall clearances are tighter than comparable 2618 pistons. I'm sure they suggest under .004".
Old 08-23-2010, 08:28 AM
89L98T56's Avatar
Measured across the skirts and at the very top of the piston, from bottom to top, not side to side.
Old 08-23-2010, 08:44 AM
KCS
Moderator
KCS's Avatar
Usuaaly the widest point is somewhere between .200-.500" below the oil ring groove, perpendicular to the wrist pin. That piece of information is supplied with each set of pistons. You should be able to get all the info you need by calling Mahle with the part number for your pistons.
Also, if it was torque plate honed, you may not see a nice round cylinder without a torque plate bolted on.
Old 08-23-2010, 01:04 PM
89L98T56's Avatar
Talked to Mahle this morning. He says the measuring point is .400" up from the bottom of the skirt. He also says that they don't even make pistons for a 3.912" bore and that the biggest he has is for a 3.908" bore. He also said recommended Piston to wall clearance is .003". but one could get away with .005". One thing I haven't checked yet is main bearings so I am gonna do that tomorrow and make sure my problem isn't a main bearing.
Old 08-23-2010, 01:12 PM
89L98T56's Avatar
Mahle technical support also said that the LS1 power pack pistons are 2618 Alloy...
Old 08-23-2010, 01:13 PM
HotSilverBird's Avatar
Well you just confirmed the pistons are wrong! It takes a good machine shop to really check the bottom end properly. You could inspect everything but without properly measuring and checking the crank how are you going to know if the crank is straight and the align bore is straight. There are so many things that need proper attention.
Without a DOUBT they made a huge mess out of the piston bores. Now you need custom pistons or another block. You could grab a 5.3 block and reuse your pistons and rods.
Old 08-23-2010, 01:24 PM
89L98T56's Avatar
The only thing that is keeping me from confirming that my pistons are wrong is the fact that to properly measure a cylinder I need to have a torque plate on because the cylinders were torque plate honed. I'm not sure how much of a difference it will make and if it will make a .004" difference or not but yea I have a feeling the pistons are wrong.
Old 08-23-2010, 04:41 PM
  #32
KCS
Moderator
KCS's Avatar
That's weird. Jeg's, as well as many other suppliers, still advertise them as 4032 alloy.
http://www.jegs.com/p/Mahle/Mahle-LS...57295/10002/-1
Old 08-23-2010, 05:15 PM
  #33
You can fit a .010 feeler gauge between the piston........no more needs to be checked!
Old 08-23-2010, 05:24 PM
  #34
KCS
Moderator
KCS's Avatar
No it needs to be verified by properly measuring with a dialbore gauge and micrometers. Using a feeler gauge is not accurate enough.
Old 08-23-2010, 05:50 PM
  #35
LS1Tech Sponsor
Beau@SDPC's Avatar
They make the power pack pistons in both alloys. Most of their flat top power pack pistons now are 4032. CORRECTION......ALL of them are. I have their 2010 revised catalog in front of me. Unless you custom ordered them in 2618, they are all 4032.
FYI 4032 will mean a little less PTB clearance. IMO it is way too much but hard to tell NOW since the pistons have been run.
Old 08-24-2010, 08:59 AM
  #36
Project382's Avatar
All off the shelf MAHLE powerpak pistons are 4032
Old 08-24-2010, 09:14 AM
  #37
LS1Tech Sponsor
Beau@SDPC's Avatar
Wrong. Most are 4032 but there are some even in the Power Pak Series that are 2618. Normally they are the dished pistons for boost. I guess even they know that the bigger boys are going to need all they can get.
Old 08-24-2010, 11:42 AM
  #38
89L98T56's Avatar
Gonna clean up all the pistons and measure each one correctly and see if somehow one got shrunk and is smaller than the rest. Also need to scrub the faces and get the PN's.
Old 08-24-2010, 01:01 PM
  #39
LS1Tech Sponsor
Beau@SDPC's Avatar
Pistons do not "get shrunk". They are what they are. They can expand from cracking/breakage/warpage, but not the other way around. You would have to wear off an obscene amount of material to make them small. It could have been mixboxed and not the right size, but that is more likely than anything else. But still highly unlikely.
Old 08-24-2010, 02:31 PM
  #40
89L98T56's Avatar
Well then my engine builder really doesn't know what he is talking about. He asked me if I ever got the engine hot and if so then maybe I shrunk a piston and that's the knocking I am hearing. He also said that even with a .010" feeler gauge between the piston and wall that that equals .050" Piston to wall clearance and that shouldn't make noise and should be alright. He said that a big clearance won't start making noise until .070" or so....
Quick Reply: Forged Piston to bore clearance?
